getting airbox back on ?
anyone know how to get the airbox back on ? (I don't mean the cover I mean the actual box that bolts to the manifold)
at the rear the hole with rubber seal slips over the inlet that emerges back right of the engine bay. There is a hook or a bracket at the top of the filter box that would seem to clip up and over a tab thats on the end of the inlet pipe. But I cannot work out how to get that clip over the tab ? It looks like you could mate the two and then twist but I simplyu cannot rotate the airbox enough to clear the tab and pus it in all the way ?
any ideas woudl be appreciated
Let me guess, you have a Vram car. You've got to rotate the MAF to get the tab to lock the airbox to the MAF. See post # 11 in my VRAM conversion link in my sig for a description of the process.
Cheers,
Joe
Cheers,
Joe
i recommend you take all the bits of the VRAM, then practice the push-to-engage-hooks-then-spin-the-airbox-to lock-into-place maneuver several times outside the car where you have plenty of room.
Then you can crawl back into the engine bay and do the same maneuver in 1/10 the space.
cheers
Craig
thnak very much guys, thats good of you
does anyone have a pic of the mass airfolw sensor and how its secured ?
everything is back on so I have no idea what to undo to loosen the MAF sensor and I certainly can't see anything
is it a hidden worm drive clip ?
Cheers,
Joe
Hi Jackal,
as Joe says there is a jubilee clip right at the top of the engine just under the sound mat. If you follow the metal pipe for the ICV you can just make it out. A 7mm socket on a wobble extension drive will loosen this off.
The non varioram MAF is held in place by two metal clips like some dizzy caps but the varioram version is held in place using a bayonet style mount. The airbox has two lugs on it with groves in them that bars on the MAF engage. An inch or so in circular movement
I loosen the MAF on the rubber elbow connected to the inlet manifold and disconnect the MAF connector (twist and pull). I then turn it upwards a bit. I then feed in the airbox and push it onto the MAF mouth firmly taking care not to disengage the rubber ring in the airbox. Using the wiring socket on the MAF you twist this to engage the bayonet connector in the airbox.
Tighten up the jubilee clip, reconnect the MAF and you're done.
If none of this works, move the AC pump off it's bracket and stick your arm under the v'ram and it all becomes much easier.
Fortunately Porsche thought of this. Fitted correctly, the worm drive bit on the Jubilee clip sits against a rubber stop built onto the rubber elbow connecting the MAF to the inlet manifold. It stops the jubilee clip rotating backwards where you can't get at it. Where it sits on the stop, it's at it's highest position (give or take) and best to get at with a socket. As long as you don't loosen it off too much you can tighten and loosen it with no problems. Pressing on it with a socket is not an issue as the stop holds it in place.
