The g50/31 Experience
#31
Its the gears on the shaft rattling, the dual mass flywheel dampens the pulses from the engine crank, the single mass does not. The problem is even more pronounced with the proper RS mainshaft with the loose first and second gears rather than machined on the shaft as in the standard road cars. It is most obvious when lugging the car in any gear most in the lower gears.
#32
Cheers,
Joe
#33
Are you in Southern or Northern Oregon. Seems like we should do some riding some time.
Cheers,
Joe
#34
I think that the CUP is worse yet based on my experience from the even lighter clutch disc and the increased vibrations not dampened by the even stiffer engine mounts.
#36
#39
That is a good point with respect to the crown wheel & pinion. I have driven a 93 CS with G50/32 and 8/32 crown & pinion. It was absolutely frantic and probably no good for more than 130 mph.
Has anyone tried this mod using the standard US spec fitted gearbox ratios?....It would certainly make a difference, just no idea if it would be for the better.
#41
Cheers,
Joe
#42
I have my eye on this mod....cheaper than going through the gears too.
#44
Cheers,
Joe
#45
I put a 7:31 CWP in the 915 gearbox of my old 911. It definitely woke the car up, but as said above, the CWP does not change the relationship between the gear ratios -- it only lowers the complete gearstack.
