The g50/31 Experience
Well done Joe, lovely job.
When we spoke about this ages ago I said that for me the downside of my 'box was the very short first gear in regular traffic - you have to rev the engine quite a bit to keep with with other cars. I see your new 'box does not have that issue having a tall first. Sounds ideal.
Best wishes
Tal
Best wishes
Tal
Ok, so this sound "the rocks in the clothes dryer" is from the lwfw? My car sounds like this in second gear under heavy load (lugging) at low rpms.
And all this time I thought that it was something like the engine tin vibrating.
I have been looking for something loose/vibrating ever since I got the car back together. Ugh!
Good to know that this is normal. I'll stop looking/wondering now...
Bob-
Bob-
Bob-
I think I'll have the same problem when I drive your 2wd Turbo ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Thanks to both you and Darrin for helping me source parts. FD Motorsports is a wonderful resource for us on this list. Mark and Darrin are very knowledgable (I didn't have to worry about getting the wrong parts), and went out of their way to remedy a problem (not their fault) that we ran into when I found a little problem with the LTW (see below). Glad I caught this before I installed everything![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Looks like it was dropped?
Did you see it before you installed it or did the fw and ring gear not mate properly?
Man you are lucky. That could have fugly.
Bob-
Joe, I just re-read this thread. I missed the damaged fw the first time thru. Holy crap! What do you figure happened to the fw? I did not even inspect mine closely before I installed it.
Bob-
Bob-
No idea how it got that way. But my friends at FD Motorsports were quick to get me a new one.
Cheers,
Joe
Best wishes
Tal
Best wishes
Tal
For those that don't know, Tal has a g50/21 in his car, not a g50/20.
Cheers,
Joe
I regeared the box in my car recently (3-6). I enter the straight at Monticello in 2nd. The 2/3, 3/4 and 4/5 shifts happen in a series of heartbeats. The 5/6 takes a heartbeat and a half, but I'm in 6th BEFORE the kink. From there to the braking zone is all 6th gear acceleration. It's quite a ride ... and, IMHO, worth the time, effort and $$$.
Thanks for the write-up. I hope these gearboxes will stay available for another couple of years. I'm already putting my pennies away. This is my 'fantasy' upgrade....
chuck
chuck
Yes the RS is something special, even more so mental behind the wheel because you know its really something special. I'll trade it for the new Husaberg 570......or two. That bike is simply the best.
Its the gears on the shaft rattling, the dual mass flywheel dampens the pulses from the engine crank, the single mass does not. The problem is even more pronounced with the proper RS mainshaft with the loose first and second gears rather than machined on the shaft as in the standard road cars. It is most obvious when lugging the car in any gear most in the lower gears.
schmidtwerk, agree on the noise, personally I find I adjust my driving to avoid lugging where possible,,although it isn't the case, it sounds like expensive repairs are required and can be alarming to passengers who hear it for the first time..
Dare I say it, but without carpet and sound proofing in a CS it is worse,,,you start off with a labouring coffee grinder noise, that quietens as the revs rise, beyond the point of the varioram coming into play it sounds like a chainsaw cutting open an angry wasp nest..this alone means I can forgive the dreadful noise at lower lugging revs, knowing what is to come.
Joe, just out of interest, why did you choose the 31 over the 30 or 32?
Bob-
