Creaking noise when driving up driveway at an angle
I purchased my '95 993 used and did have a PPI performed...
....here's my problem,
when approaching my driveway I hit it at an angle so I don't scrape the bottom of the car. When I do this I hear creaking inside the car, like metal rubbing against rubber. Or rubber against glass. Is this normal or do I have a car that was in a serious accident?
Thanks.
Thanks.
Once again geolab is on the spot. This is a great fix and used it when I had my old cab. On my new cab I lubed the gasket for the windshield prior to install. The creaking is normal but can be diminished.
Mike
Mike
Brian,
It's a rope that fits under the rubber seal for the back window. I bought it from Sunset. I guess it keeps the window from moving around so much. It did help with he creaking.
I did play the other day but it did start raining on the 17th hole.
I look forward to seeing you in November for Palooza!
Brian,
