FAB Speed Cat-bypass
I have a set of FABSPEED CAT-BYPASS for a 1995 Narrow Body 993 for sale. These will fit 993s with the Bischoff Factory exhaust. They are in excellent condition. About a 7.5 out of 10 condition. I just sold the car and these need to go too. There is a noticeable difference in Horse Power and torque. These also eliminate the flat spot in the REV Band. There are no check engine light issues with a 995 OBDI. The best reliable power gain for the buck. This item is used.
• +12HP and significantly more torque. Saves 14lbs/6.3kg over stock catalytic converters.
• 993 Cat bypass pipes/cross pipes are different for certain years. 1994-1996 1/2 993's and all 993 SUPERCUP cars (1994 to 1997 993CUP) have Bischof oval 3 bolt flanges. 1996+1998 993's are all Gillett round 3 bolt flanges. YOU MUST CORRECTLY specify flange type when Ordering. When in doubt go check especially the late 1995 and early 1996 cars as this was a “cross-over year” and flange style changed during the year.
• T304 Stainless steel C.N.C mandrel bent with polished show car mirror shine.
• Simple and easy Bolt-on and bolt-off when you need to!
• Cat bypass pipes & Fabspeed sport exhaust makes as much or more horsepower then virtually all aftermarket exhaust systems.
• Best PROVEN performance value on the market.
Asking $390 Canadian
Located in Toronto
Cheers,
Al onecutetigger@hotmail.com
Located in Toronto
Cheers,
