leads wanted; re: metal valve stems...
This is a valve stem that came w/ my Kinesis wheels, It fits great and looks great, but the gaskets are getting old and leaky(as you can see).
Soo I'd like to replace the gaskets or replace the whole valve stem w/ identical units, small chamfered base, no external nut.
All the ones I seem to find these days are like this, a little larger base & external nut
Any leads on the original are greatly appreciated
I got these from Tirerack a couple of years ago.. they weren’t on the website but they have them....
If this is what you are looking for, PM your address, I don’t need them anymore.. You are welcome to them.
Jeff
Bill:
if jscott82's don't work I have a brand new never used set of OEM Porsche metal valve stems. They look longer than the ones pictured above, but it may fit what you need.
Mike
Mike
Fikse uses Alligator valve stems.
They make them in different hole diameters:
http://www.alligator-ventilfabrik.de...r_metal_valves
There is also Myer Tire Supply:
http://www.myerstiresupply.com/shop/...er+Tire+Valves
Stan
Stan
Yes, those are the ones. I'll PM you
Stan
Stan
Thanks!
