Need HELP with CF heater bypass tube..
I have a '97 varioram and i dont know what to do with the vaccum hose that went in the actuator in the front part of the heater system...where do i put it? what do i do with it after i install the bypass tube?
Targa
You mean the little rubber pipe. There should be a nosel for it to connect to the CF bypass pipe, and the other end goes it ??? Check the pic out - hope this helps.
The hose pictured transfers heated air to the rear center reflector assembly to prevent/reduce condensation there
