Results are in...What do you think
PPI results, thoughts plz since this is my first P-car. 1-6%,6-5%,2-5%,4-4%,3-5%,5-5%. From reading the boards this sounds pretty good? Also, oil cooler temp sensor bad, lower valve covers requre replacement, lowr plug wires needed, heater blower relay bad, rear blower speed resistor bad, heater controls at dash not working properly. Windshield washer inoperative, right rear wheel bearing needs replaced. All above was what was found on the PPI, anyone see anything major that would prevent from buying car. my95, 46000 miles, paint and ext is 9 out of 10. Very clean car.
That looks ok to me. The heater controls are the only thing I would look into more closely, making sure the other minor related items are fixed mayfix the CCU operation.
Someone correct me if I'm wrong but the CCU can be refurb 'd for about $250 by a forum member.
My (wife's) first P-car. My95 (2/94) cab, white w/black top. 46k miles, tip,upgraded headlights,sidemarkers. New tires and wheels, also got the orig. wheels with 1 year old tires. Have extensive maint. records since 2004, partial records from before but have the 15k, 30k records. Upgraded stereo, chip, sway bar and some other goodies. However, the car is at the dealership and I can't pick her up until friday. PO agreed to split PPI repairs with me and getting them done while the iron is hot. Also, just sent check for 2 year Rennlist membership. Thanks for all comments/advice on previous posts while I was looking. I WILL get the mandatory pictures as soon as I get her home.
