Diadem bulb locator help
I am looking for a diadem bulb for use with the updated clear front lens assemblies. The only one that I can find (including FVD and european sources found through an internet search) have a single contact point on the base and the pins are in one of two positions, directly across from one another or at 4 and 7 o'clock. The recepticle on my early '95 uses a bulb with 2 contact points on the bottom and pins that are at 3 and 9 o'clock but staggered - a 1157 style - a common US car type bulb. Does anyone know a source for a diadem bulb like an 1157? Thanks for any help.
Don't know if Osram makes them for 7528s yet but you could try these
http://www.stealthauto.com/Products/...SBCA-7528.aspx
Or if you are feeling wealthy, go LED
http://stores.channeladvisor.com/six...%201157%207528
dave
dave
