993 Forum 1995-1998
5th Brake Light
Old Aug 8, 2009 | 02:08 PM
Raptor's Avatar
Raptor
Default 5th Brake Light
Why are there two brown leads into the left-side brake light
This-is-the-mod-of-the-week and I have everything ready but can't figure why the wiring is this way. NEED HELP.
I am putting in the 4th/5th brake lights and have kicked it up a bit with this, too: http://www.kahtec.com/smart_stop.htm
I assume the white/brown (or is it white/red) is the power and brown in the ground;but why are there two browns into the left-side brake light? Does it matter which one is selected as the tap-into-wire? Any help greatly appreciated.
Right Side:
Left Side:
Old Aug 8, 2009 | 02:14 PM
Raptor's Avatar
Raptor
Right Side:
Left Side:
Old Aug 9, 2009 | 01:06 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Those are the B/U light sockets in the center section. Tapping into them won't turn on the brake lights. Of the three wires coming to the brake light on the driver's side, I would tap into the brown wire (ground) and the black wire (hot) and run them to the respective ground and hot sides of the new brake light sockets.
Old Aug 9, 2009 | 07:13 PM
Raptor's Avatar
Raptor
NC: Thanks. I misspoke on the original post. Meant BU light, but the question was still lame. I didn't relize that the second ground on the BU light is just a return. I wasn't sure if it mattered where I tapped into the ground. I ran the power from the right rear brake light and used a speed-tap to the primary BU light ground. That way I only had to run one wire from the brake light. Nice mod, as it really lights up the rear. Thanks to everyone who has done this and posted help. The 3 phillips screws would have been perplexing 'cause of their length, without the advice from RL.
