Hydraulic "Lifter" Anatomy - pics
With all of the lifter talk these days I thought I'd post a couple of detail pics of the part in question.
This is an old, failed lifter. The seal is toast and it has marks on one end from "removal process"
Seals can be bad and not come out in pieces as this one did.
It is also worth noting that a "collapsed lifter" would be caused by the internal spring failing.
The grids squares are 1"
Thanks for that picture MArk.
Interesting to see a spring in there, I always thought that the fact that they were hydraulic meant that fluid inside the lifter was the one keeping the pressure agains the valve.
I see now that they are in fact, some sort of a miniature shock absorber...
King of Cool
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I see now that they are in fact, some sort of a miniature shock absorber...![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Similar to the chain tensioners on these engines. There is a spring but the oil pressure actually does the tensioning.
wish I could photoshop...
Makes sense. Thanks for the clarification.
Seared
From a design standpoint, the spring is in there as Mark says to keep the cavity open. The oil pressure can find the void easily due to the path of least resistance into the lifter itself.
One other neat point, that is if the lifter is collapsed by design or by failure (as in no spring by design or as we see sometimes - failed internal spring) the lifter could get side loaded and stuck closed, causing some racket and warranty expense...thus the spring for a viagra effect.
