993 Forum 1995-1998
Looking at 97 c4s repairs
Old Jul 18, 2009 | 10:16 AM
96C4S roller's Avatar
96C4S roller
2nd Gear
Default Looking at 97 c4s repairs
Need a little guidance. I am looking at a 97 C4S and it needs a DME relay, Fan Airduct - A/c Leaks - Clutch and RMS leaks and is missing the rear undertray.
The cost to repair is about $6K .. Does anyone know about the cost I should pay for the RMS (rear main seal) and the clutch? Also recommendations on the clutch.
Old Jul 18, 2009 | 03:04 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Moved from RL Posting Guidelines forum to 993 forum...
Old Jul 18, 2009 | 03:22 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Hi,
You didn't say how many miles are on the car, but I'd offer some thoughts,.........
1) DME relays are a wear item: these do fail and one should always carry a spare.
2) Same principle; fan airducts don't last forever due to heat & age and thats not a dealbreaker.
3) A/C leaks can be normal depending on mileage. Its not difficult to leak-test the system and recharge it.
4) If it has over 60K on it, its in that window of needing a clutch and again, thats a normal wear item just like tires. I always replace the RMS when doing a clutch. Labor rates vary widely so its difficult to estimate your cost on replacing all this.
5) IMHO, having no rear undertray is a big plus and I'd be grateful for that.
Make sure you get a thorough PPI done that includes a leakdown test.
Old Jul 18, 2009 | 05:07 PM
goofballdeluxe's Avatar
goofballdeluxe
Steve is a 993 genius, so I'd take his word as gold.
