CCU connectors
CCU connectors
I have been reading the threads of the CCU for HOURS and have started to remove the CCU from the dash. Details at p-car workshop. Instructions regarding connectors are "There are 2 electrical connections on the back of the CCU. I took a picture to give you an idea how they disconnect. They swivel lock into place. Take your time and look at the mechanism. Once you understand it, they are easy to remove." Could someone be a little more specific? HOw can a 32? pin connnector "Swivel" into place.
Also is it "normal" for the little fan on the CCU to run even without ignition on? Mine does.
Just a little advice. When removing CCU the nails should only go in aboiut 1.5 inches. ANymore just jams the CCU into place. Thanks for the
