993 Forum 1995-1998
Idle problem driving me nuts!
Old 02-13-2014, 07:44 PM
BobbyT
BobbyT's Avatar
+ what Garth said. I've had this problem on other cars after washing the engine. Some of the sensors/harnesses get damp, and it throws a fault code. Clean up as necessary, follow Garth's tips on the O2 sensor harness connections, and drive the car some to dry everything out. Considering the sequence of events leading up to this problem, I'll be you don't need to replace any parts.
Old 02-13-2014, 08:20 PM
nine9six
nine9six's Avatar
Originally Posted by Amfab
I am going to order some new O2 sensors. Part of my question is; are the codes and the idle problem related?
It may be apples and oranges, but I solved a hunting idle problem in an 87 by replacing the O2 sensor.
I am with the others in questioning why you would look to try to fix everything except what is thowing the codes?
Check the voltages at the sensors to be within spec...If OK, check for shorts...One short in an O2 sensor will throw codes in other sensors as well !
Check post #5 of this link where Jason linked the workshop manual diagnostic pages...
https://rennlist.com/forums/993-foru...-o2-codes.html
Old 02-13-2014, 08:23 PM
lopro
lopro's Avatar
great links thanks for the post I really needed these, best forum ever
http://members.rennlist.org/jandreas/p0131.pdf
http://members.rennlist.org/jandreas/p0137.pdf
http://members.rennlist.org/jandreas/p0151.pdf
http://members.rennlist.org/jandreas/p0157.pdf
Old 02-13-2014, 10:09 PM
pp000830
pp000830's Avatar
Received 1,547 Likes on 1,093 Posts
Make sure your car is providing 13.5 volts at idle. It seems to me the engine can be squirrely if the running voltage is a little low.
Old 02-13-2014, 10:41 PM
e3photo
e3photo's Avatar
You all do realize that this thread is 4 1/2 years old,don't you? I just posted my remedy in case it helped someone. I hope the OP has solved his issue by now.:bang head:
Emerald
Quick Reply: Idle problem driving me nuts!
