RS tie rods ?
I am aware that there is a solid tie rod as fitted to the GT2 evo (and sold as part of a kit at Carnewal as a bumpsteer solution)
but is there another RS tie rod that still had the rubber cylinder but less play than the standard 993 tie rod ?
993 tie rods consist of 2 parts, inner and outer
which outer you use depends on which upright or wheel carrier you use, stock uprights need stock outer end, RS uprights need RS outers.
either of the outers can be used w/ your choice of 3 possible inners, stock w/ rubber, RS w/ harder rubber, solid GT2 Evo.
The issue is that usually outer and inner are sold together, I haven't seen them sold as separate pieces.
yes thanks, i know about the inner vs. outer & can order the solid inner tie rods separate
just wanted to confirm the existence of a 3rd 'RS' inner tie rod that has less play than stock
Hi Jackal, if I'm reading correctly you're saying the inners can be ordered separately. Is that correct?
If so, I'm interested in who sells them! Thanks in advance.
