Airbag Control Unit, How to remove it???
I did some searching...
I have a 1996 C2
The unit is now found.... How do you remove the tamper-proof nuts without the special tool? Need to reuse the nuts if possible.
Many THANKS!!!!!!!!!!!
I have a 1996 C2
Ah Ha!!!!!! There's the little sucker.... Mine is the original unit (p/n 993 618 277 00).
I see anti-tamper nuts holding it in. Anyone have a good method for removal?
I am now going to purchase the newer 996 unit as shown above and replace the old unit.
Thanks Bill!!!!!!!!!
The workshop manual specify's a special tool for removal, its basically a socket with teeth machines into it at an angle. Looks like a part that snap-on or mactools would make but I have not checked.
Regards
Regards
You can get them loose gently tapping them counter clockwise with a little chisel or standard screwdriver, once you get them turned about 30 degrees they will spin right off. Screw re-using them but if you must just reverse the install.
I assume the security bolts are the same as the ECU. I removed them by making a slot with a dremel and then used a screwdriver. I replaced mine with standard nuts.
356Racing, That sound good to get them off!!!!
Crimson Nape Racing, I will most likely use Nylock nuts instead of the OEM.
THANKS Guys!!!!!!!!!!!!!!!!!!!!! Great info.
