How to fix a wreck at home 101.
Well first off, I have never done this and sorry for the cell phone pics but its all I had when the time came to take pics. Its my first paint job and I think it turned out great. Im going to get it covered with 3M film so I hope it last a while.
First pic is of the damage. It was not too bad but I decided to re spray the whole front of the car as it was very badly pitted up.
![](http://i160.photobucket.com/albums/t167/Gasser_photos/Crash.jpg)
![](http://i160.photobucket.com/albums/t167/Gasser_photos/crash2.jpg)
I sanded to bare metal, pulled the dent out with a post welder and filled the low spots with body filler.
![](http://i160.photobucket.com/albums/t167/Gasser_photos/repair.jpg)
![](http://i160.photobucket.com/albums/t167/Gasser_photos/repair2.jpg)
I then sanded and prepped the rest of the front, removing the headlight spray nozzles, the windshield spray nozzles and was ready for primer.
![](http://i160.photobucket.com/albums/t167/Gasser_photos/prepped.jpg)
![](http://i160.photobucket.com/albums/t167/Gasser_photos/primer.jpg)
Next up was the paint and Clear. I had to repaint the passenger fender as I had a thin spot in the clear and sanded into the color coat enough that I messed it up. Just part of the learning curve...![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
![](http://i160.photobucket.com/albums/t167/Gasser_photos/paintandclear.jpg)
Finally test fitted the front end parts and made my new mesh metal cooling ducts that will feed extra air to the two front oil coolers.
![](http://i160.photobucket.com/albums/t167/Gasser_photos/partstestfit.jpg)
Car put back together and was wet sanded and buffed to a shine. No wax and car put into the sun to bake a little. 3M clear bra is in its future.
![](http://i160.photobucket.com/albums/t167/Gasser_photos/finishednose.jpg)
![](http://i160.photobucket.com/albums/t167/Gasser_photos/finished1.jpg)
![](http://i160.photobucket.com/albums/t167/Gasser_photos/finished2.jpg)
Not bad for a beginner...
WOW...Awesome job. You obviously have done this before. This is DIY that I won't be attempting. It takes a lot of skill and practice to do that, and I rather not acquire those skills in my own car. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Does the floor on the garage shows a bit of red too? or is it just the picture? Please tell me that you covered the white car next to your red one while you were spraying.
Unbelievable? I spray painted an extra set of track wheels a couple months ago. That said, I definitly would not paint my own car!
Too funny.... I'm doing the exact same .... including removing the washers and mesh grills.... Only I’m about two weeks behind you... I just finished rough fitting.... still have sanding and paint to go..
I hope it turns out as good as yours.
