Torque spec question...
Seared
If you are asking about the small socket head bolts that fasten the uprights to the heads, give me a minute. I need to run out to the shop and check the manual.
EDIT: I could not find the value in the 'Engine' manual and will check in the 'Fuel' manual tomorrow.
Andreas
Andreas
Lifetime Member
Lifetime Member
Andreas,
If he is referring to the 7mm bolt, I don't think there is torque spec. for that. You don't really need it, just tighten the strap down tight, that's all.
There is an old Chinese saying that applies to this, "Take off your pants to fart". Those who speaks Chinese should find that funny. :P :P :P
Seared
Andreas,
I think the question refers to the small bolts that hold each intake riser stub to the heads. The rubber boots slide over these and are held in place by clamps.
Abdreas
