Oil level sender unit easy to replace?
The sensor is very easily accessible, just take off the passenger side skirt, rear wheel and the rear inner fender (plastic). All you need is a screwdriver and a 10mm socket or wrench.
I think the sensor is just bolted to the sump/reservoir.
Seems to be:
https://rennlist.com/forums/993-foru...vel-gauge.html
(That thread is more about accessing/tweaking the sender unit to make the gauge more accurate, but you get the idea.)
