Another way to get at the ignition wire blocks
In reading the DIY (http://www.pcarworkshop.com/index.ph...re_Replacement) for replacing the spark plug wires, I knew I couldn't get my hands and arms in between the intake runners. After looking at the possible ways to get to the two wire blocks that have to be removed, I removed the lower throttle valve ('96) which gave me a large area for reaching the four screws hold down the wires under the intake.
Easiest way is to lower the motor as much as possible on the engine mounts. Then simply (relative term) loosen the six clamps holding the intake to the rubber connectors to the fuel injector blocks. Now raise the intake. Use LOTS of whatever oil spray you have when reinserting the runners in the rubber connectors...
Lifetime Member
Lifetime Member
Bob,
I found using brake parts cleaner works well as a lub to disconnect rubber hose and connectors. Just pry open the rubber hose a little and spray a little BPC and then it comes off with ease.
Just sharing some tips.
Yep Robin, just as long as you use something and it will come off and go on MUCH easier...
FWIW, I believe I've read that silicone is really, really bad for catalytic converters so I wouldn't use it anywhere on the intake system, especially inside the rubber mating tubes. Just my $.02
http://www.picoauto.com/applications/lambda-sensor.html
A lambda sensor’s normal life span is 30,000 to 50,000 miles, but the sensor may fail prematurely if it becomes clogged with carbon, or is contaminated by lead from leaded petrol or silicone from an antifreeze leak or from silicone sealer.
I believe it's the O2 sensors that fail with exposure to silicone.
In any event, you'd still be running the risk of having silicone being breathed in and exhausted out past the sensors. Lambda sensors aren't cheap and there would be four of them to replace!
