PSS10 Extra Lower Locknut Issue
Here is another option for installing the lower extra rear drop link mount lock nuts. These have to be ordered separately as they are not part of the std kit ( I'd post pics but my computer is being reloaded due to a defective new Seagate hard drive).
As soon as I installed the lower lock nut and threaded the drop link mount down onto it I found that there was interference. The lock nut will not contact the lower face of the drop link mount as it hits the angled part first (here is where I need a pic). You have 2 choices at least. You can grind a lot of material off of the mount or you can install some big spacer washers. I found some 2 inch machine bushings (large washers) and used them. The id has to be ground out slightly to fit but it works well. Here is the link to the mfg's website
http://www.dynaline.com/data/Generic...ery%20Bushings
You need a couple of the 22730 washers per side. You can use one washer but you will still have to do a small amount of grinding. These washers are stocked at industrial nut and bolt supply houses.
Are you talking about the 3 black locking rings on each rear shock? Two interlock to adjust spring ride height, and the third one locks onto the droplink mount?
If so, the lower collar sits on top of the droplink mount. If you align the droplink mount properly, and then tighten it against that black collar, it should not move at all. Mine have been on for just under a year. So far nothing has ever moved.
I think using these washers to add an extra lower collar is a bad idea. Isn't the goal to have this extra collar (which I still think you don't need) interlock with the bottom of the droplink mount? If so, two washers would only prevent you from having a real tight lock. It might negate the benefit of that extra lower collar.
Just my opinion, I could be wrong.
Cheers,
Cheers,
I am talking about adding a 4th lock nut below the mount. This seems to be a common recommendation around here.
Again, a pic of what I am talking about might help.
There are lots of pics of broken mounts and links on this forum so I thought I would be safe instead of sorry. Yes, perhaps properly tightening the top mount lock nut might be enough although heavier sways must exert more force on the mount which could possibly break it loose. I don't see any downside to the washer.
Seared
ps It will be a difficult sell if they don't think that there is a problem. Maybe they have the same engineers that designed my BMW tranny and software.
Cheers,
Cheers,
I did not add the 4th lock ring either. I also couldn't see how you could add one w/o some grinding or modification to the mount. I marked the drop link mount and the shock body so I can check to see if I'm getting any movement and 6 months w/o a problem. Now I've only done a couple of Auto-crosses and street driving. Now on the track I might be concerned.
see photo's below of before / after grinding.;
cost = pretty much zero if you already have a compressor, die grinder and rotary files.
thanks for the tip on the alternative, but the link didn't work for me today
Craig
The link didn't work for me either today but you can just go to the main page. The washers were about a $1.25 each. If I had more time and access to a lathe I would just make spacers.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
![](http://i243.photobucket.com/albums/ff169/rennsport751/IMG_0474.jpg)
![](http://i243.photobucket.com/albums/ff169/rennsport751/IMG_0481.jpg)
![](http://i243.photobucket.com/albums/ff169/rennsport751/IMG_0472.jpg)
I will generously provide field testing for you Chris. I might even pay the freight. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
ps I can't wait to get the car on the road and try out your control arm bushing upgrade
Just received the extra locknuts. They are not the same and I probably didn't need the grinding and washers ![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
Here is my post and pics in another thread
https://rennlist.com/forums/993-foru...n-collars.html
