Sunil,
Can't help you out with the reading you are getting on fuse 12. I was having a similiar issue 2 years ago and it turned out I just needed a new battery. When is the last time it was replaced?
Hi, nope. I did not, I was thinking of removing the rear wiper. However I'm guessing that it's not normal for the to be a spike in the current when the ignition is off.
I had a similar problem with my car where the battery was being drained in under 24 hours. The ignition switch was bad and wasn't turning off power to some of the accessories in my car.
