CR-210 HELP What am I doing wrong? Pics and description
Mike,
There are a number of threads on installing the Becker Traffic Pro in MY95 cars. The Traffic Pro has the same chassis as the 210, the 1995 CR-1 one harness can be adapted with conversion harness from Becker. That is what I did. I did the conversion back in '03 but i still have my notes if you need any help.
Dave
Dave
Mike check this page:
http://www.waycoolinc.com/z3/01/081501/E36Z3.pdf
There are a lot of similarities to what you are trying to do.
My '95 993 came from the factory with an Alpine radio. When I replaced it with a CDR-210 I had to send the Alpine radio to Becker and they made an adaptor harness (~$100) so the Becker unit could be installed without rewiring.
What about this: The Becker connectors are essentially the same as the Blaupunkt. Since your power connectors work, you really just need to buy a new adaptor for the RCA outs to hook up to the Hi-Fi option amp.
http://www.midwestelectronics.com/bl...ter-p-161.html
is the Blaupunkt online order site. Check out the connector to see if this will work.
^^^ I finally figured that out. The car came with a CR-1 and the swap over is too time consuming at this point. Dudley a Rennlister pretty much gave me his old CR-1 for the cost of shipping. When I have the car for awhile I may revisit the idea of a swap. I have got too much on my plate with this car and don't want to add another project. Thanks for the confirming information though.
Mike
Mike
