993 Forum 1995-1998
Another H&R Sway Bar Question
Old 03-13-2009, 10:40 AM
  #31
DaveM993
DaveM993's Avatar
Originally Posted by Van1
In theory, doesn't stiff up front and loose in the rear exacerbate understeer?
Yes. But my alignment/camber had a little oversteer in it already. There are only two settings on the H&R front and back...so frankly other factors will have a greater impact on over/understeer than the small relative adjustment of the H&R sways front to back.
YMMV.
Old 03-13-2009, 10:44 AM
  #32
DaveM993
DaveM993's Avatar
Originally Posted by jungleboy
That's good to hear. Any issues with the interference that everyone's faced at all? Also, what's your final ride height that you've set? Thanks...
Interesting...
No interferences, stock drop links and the ride is LOW. The front is a little lower than RS...I like what the rack does for the handling.
Old 03-13-2009, 11:55 AM
  #33
jungleboy
jungleboy's Avatar
Thanks for the answers Dave, the car looks excellent!
Old 03-13-2009, 07:45 PM
  #34
DaveM993
DaveM993's Avatar
I meant 'rake'....
Old 03-13-2009, 10:37 PM
  #35
matt777
matt777's Avatar
Has anyone built their own drop links or seen the Tarrett's? I'm in the process of selecting the spherical rod bearing components to build my own. The only issue is finding 10mm threaded tube/hex bar. If it was 3/8" then things would be good. I'm curious if Tarrett or anyone else has gone 3/8" instead of 10mm. I'm worried that the 3/8" will pound out with the extra clearance in the sway bar holes.
Old 03-14-2009, 02:27 AM
  #36
axl911
axl911's Avatar
I built mine own for $30. Works great!!!
https://rennlist.com/forums/993-foru...droplinks.html
Old 03-14-2009, 02:29 AM
  #37
Martin S.
Martin S.'s Avatar
Default Drop Links......
I have been running the Tarret's for a couple of years it seems. Fine product with an incredible support from Ira Ranin, the owner.
I have a 993 Coupe (Than you Jesus!!), with the TRG sway bars and Tarret drop links front and rear. Great products!
Old 03-14-2009, 12:13 PM
  #38
matt777
matt777's Avatar
I do remember the post now. I didn't realize you had posted the sizes (3/8"). That would make things easier as Midwest doesn't have the 10mm threaded tube/hex bar. I could use rod instead though w/female sph rod bearings (front).
The rear links should be easy as I doubt there is need for tube as they are short unless you are running the sways underneath. I probably don't need this set-up but one of my front links has a torn rubber. Back to the drawing board.
Quick Reply: Another H&R Sway Bar Question
