Center Caps Refurbishing
I recently picked-up a set of 7 & 9 x 17" Cup II wheels in pretty good shape except for some minor curb & face-down-ground rash on the rears. Included with the wheels were four center caps, part #993.361.303.07, which cleaned-up surprising well, and exhibit only slight fading and discoloration:
My problem is that none of these center caps firmly affix to the Cup II wheels. I even tried them on D-90 & new Cayman wheels, with the same result. When I received the center caps from the previous owner, several had tape on the plastic retaining prongs, which worked somewhat, but which probably made the plastic yield a little further when installed over time. I don't want that half-a$$ fix going forward, if I can help it. The prongs have no discernible damage like cracks, or evidence of repair:
![](http://members.***.net/m3b/images/CenterCap_Edge.JPG)
Anyone have a fix for the retaining prongs, or are they just plumb worn out?
-------- revised 3/10/09:
After additional cleaning of the wheels and inspection, I discovered the prong surface responsible for engagement is as indicated below on the bottom prong in Orange. For a permanent fix, how about building-up theses prong surfaces by gluing a rub resistant film (Mylar maybe?) in the shape of a right-angle "hat", i.e. "^", as depicted on the top prong?
I would not bother with the epoxy treatment. I had a similar issue and just used a dab of RTV silicone on the prongs to provide a secure fit ... easily removable for tire changes ...
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
FlatSix911,
Thanks for the RTV silicone suggestion, hadn't thought of that, might work for me. How's the silicone adhesion to the plastic? Do you have to re-apply after each removal?
993C4Smontreal,
The crests had significant scratches and the silver had only slight scratches, so I used a small dab of rubbing compound on the clear-coat over the crests, followed by Meguiar's polishing glaze over both sections. The rubbing compound and polishing glaze are both clear-coat safe. Scratches all gone.
993C4Smontreal,
FlatSix911,
993C4Smontreal,
993C4Smontreal,
