Where to connect a harwired GPS etc?
I am hard wiring a GPS power source (its actually to power my track camera) and was wondering where would be a good place to tap into.
This is for my track car, but I would like to avoid a long wire run, and would like it to be hidden.
Switched would be better than unswitched, and fused of course.
I was thinking that I should tap into the back of the cigar lighter, as a normal GPS, radar detector, etc. would use the outlet for power. I am really doing the same thing, except using the hardwired method.
Track camera is mounted on the horizontal bar behind and between the 2 front seats, and I figure I will run the wire down the cage and under the carpet then up under the dash. Alternate suggestions are welcome.
TIA
TIA
I run my RKE/alarm and data logger off of the (disconnected) passenger seat's power harness.
I run my wideband O2 sensor off of the wire harness for the (disconnected) rear wing controller under the dash.
I run my V1 by splicing into something in the center console. I forget what I tapped, but IIRC I just following the procedure on p-car.com/diy/diy.html for hard wiring a V1.
Wouldn't the cigarette lighter be tough to get to??
All excellent ideas; thank you to everyone that contributed.
BTW, is the p-car.com site gone? I haven't been able to pull it up in the last 24 hours.
