gap between front bumper and hood (pic)
ive looked at other 993, most trunk lids are flush to the bumper, i did put on a front euro bumper but never noticed the gap, body shop said that as close they can get it. is this true or just lazy, can this be adjusted?
cabrio993 iill try to take an other, bu if you look real close you can see the rubber piece, thats not flush with trunk lid. now the question is, is the trunk lid to high or the bumper to low? Btw always liked your car
I just went to the garage and meassure mine. The gap is wider than the rest of the gaps of the car. Mine messured 1/4 of an inch with the rubber piece showing flush with the lid and the bumper. I think it is very noticeable on white cars.
I like your cab as well...![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Here is a picture of my bumper gap as a reference. Not the best angle but I hope it helps.
so you are saying with out the rubber piece there is a gap, but your lid is flush with the rubber piece and the rubber piece is flush with the bumper?
Mayb e when they installed the bumper, they let the rubber piece recess too much?
There is a metal plate with 4 screws that hold this rubber piece to the bumper. if you losen these screws, you can adjust the height at which the rubber piece sits.
Adjust it so it is slightly above the surface of the bumper and the lid.
Maybe this is the gap you are seeing?
If you're using a point-and-shoot camera, try adjusting the close-up focus by pressing the "flower" icon on your camera. You should get sharper close-up images that will be more helpful for other Rennlisters.
