993 Forum 1995-1998
very odd suspension behavior ('95 C4)
Old 02-09-2009, 09:49 AM
bart1
bart1's Avatar
Originally Posted by murfysflaw
Interesting. I've heard of similar symptoms in lifted Jeeps called "death wobble", but it's normally caused not completely taking care of all the things necessary to properly lift a Jeep 3+ inches. Gets lots of things out of alignment and many people try to do it on the cheap. Can't imagine what it'd be on a Porsche aside from what others have suggested with the tie rods, control arms, and finally ice/snow buildup.
Death wobble is usually from caster being off on lifted Jeeps.
I would do some real inspecting of all front stering and suspension connections in the OPs case. Could be ice, but that sounds like an odd one to me.
Old 02-09-2009, 08:09 PM
gtroth
gtroth's Avatar
Shocks don't seem too bad, actually, despite their age. No bounce, just nice damped response. And I flog her pretty good around pretty bumpy curves almost every day with no loss of confidence. And I'm pretty sure the shimmy I'm experiencing wasn't brought on by a bump.
Perfect today (3 straight days of warm weather). If it happens again when it cannot be ice, I'll have the pros take a look - everything seemss right to me.
Old 02-09-2009, 08:23 PM
fast_freddy
fast_freddy's Avatar
I agree with the ice.
Old 03-03-2009, 10:50 PM
gtroth
gtroth's Avatar
Alright, it's happened twice more (5 times total), all times the day after the car has seen some snow/ice/slush. All times I can stop the car for a minute or two and drive off and it's fine for some time (many days...)
So while it still could be ice, it seems unlikely that it would happen so often. I'll let the pros look her over see what they can find. Keep you posted.
Old 03-03-2009, 11:16 PM
helmet155
helmet155's Avatar
I still think it is front bushings. They may look OK but get a large prybar and you'll see how wiped out they are.
Old 03-04-2009, 11:30 AM
matt777
matt777's Avatar
That is an easy one to assess. It's worth checking out.
Old 03-04-2009, 12:23 PM
murfysflaw
Wallflower
murfysflaw's Avatar
There you go... Couldn't remember, but I know I had it all aligned and everything after the lift and never had a problem.
Old 03-04-2009, 12:54 PM
Bruce SEA 993
Bruce SEA 993's Avatar
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
Ahhh...Ice forming inside your tire from the miosture in the tire.
At cold temps the moisture condenses and refreezes in a lump at night. In the morning after driving 10to 15 minutes the tires warm up enough to let it loose. Then you stop and the water melts and evenly distributes.
Old 03-04-2009, 12:56 PM
AOW162435
Seared
AOW162435's Avatar
Hmmm... So he could drill a hole in each of his tires, let the water drain out, and then plug each hole.
Andreas
Old 03-04-2009, 01:01 PM
cdmdriver
cdmdriver's Avatar
Andreas
Old 03-04-2009, 04:22 PM
cabrio993
cabrio993's Avatar
Andreas
Hmmm...I thought long about this and figured that he could also lose air if he did this.
So, maybe re-routing the SAI valve to the tire valves could work. On startup, the SAI pump will flush any water buildup in the tires and refill them with air at the same time.
Old 03-04-2009, 05:19 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Andreas
Thats been successful for me as well, but I've elected not to plug the tires to keep THIS particular "problem" from recurring.
I deplore doing things twice,...
Old 03-04-2009, 05:57 PM
helmet155
helmet155's Avatar
Fill with nitrogen in the future to minimize the moisture inside the tire...
Old 03-04-2009, 06:49 PM
AOW162435
Seared
AOW162435's Avatar
GROTFLMFAO! (Gently....., due to back surgery)
Andreas
Old 03-04-2009, 07:47 PM
matt777
matt777's Avatar
None of you guys are allowed to work on my car.
I've never heard of ice inside the tires but the humidity is low here. You would think that the ice would be distributed and not affect balance. Mechanical looseness can cause inconsistent vibration. You would think the tires would be worn if it was plain front end wear.
Quick Reply: very odd suspension behavior ('95 C4)
