***Xenit Special***
#47
First thanks Cactus for doing this , my case should be here in a week .
My white cab I did it with high pressure steam cleaner , simple green & elbow grease with tranny and engine out no cosmoline there.
The blue riviera I`ve done the wheel wells with simple green and small steamer . Will try this product for cosmoline under belly and will report back .
Btw the white cab won two (07 , 08 )" best in class " light concourse competition
Cheers Guy
Cheers Guy
#49
Super Moderator
Needs More Cowbell
Needs More Cowbell
Email sent. Thank you.
Xenit works great for getting rubber marks off of your car after a track day.
I also use it on my son's karts to clean marks off the bodywork/decals.
#54
This is the email I got back from them.
"Thanks for your interest. Please call me if you want to order & pay by credit card or you can mail your order along with a check for $31.41 for the case. Shipping is free.
Thanks,
Dave
Dave Scranton
Inside Sales Manager
Stoner Inc.
2003 Malcolm Baldrige Award Winner
800-227-5538, ext 3122
800-515-5150 FAX
dscranton@stonersolutions.com"
Thanks,
Dave
Dave Scranton
Stoner Inc.
800-515-5150 FAX
#55
Does anyone have any tips on what NOT to use Xenit on?
#56
Noodle Jr.
From Dave at Stoner:
Be very careful on paint. It will remove stubborn dirt, grease, grime, sap, etc from paint but make sure you wipe/rinse it off quickly or it may remove the paint itself. Another surface to be very careful on is clear plastics.
#58
Noodle Jr.
The stuff is strong so use caution and test a spot before you go soaking unless it is on the bottom of the car Due to the heavy response we got Dave and I are going to talk about giving you guys a monthly Cactus special. Maybe More Shine (for tires) next?!?!
#59
CACTUS & Dave-
"Attaboys", well done, Bravo Zulu and YeeHaws! UPS just arrived and I just had to do a quick test. XENIT is da bomb! That stuff cuts cosmoline like nothing I've ever used before. Question, tho: Based on your caution/warnings above, will it cut the clear coat on the backside of wheels? So many times, I find cosmoline overspray on them. Thanks!
#60
Though I am not sure I want to say "give me the Cactus Special"....seems like that could go wrong
