Short Shift Advice Requested
Hi. I'm a new 993 owner, after having a 968 for 7 years. My '95 993 coupe has lots of upgrades and extras but one thing that's missing IMHO is a short shift kit. The throws are way too long for my taste.
Can anyone recommend a manufacturer or model? I've found the B&M model at Pelican Parts. Does anyone have any experience with it?
Thanks in advance for your help.
Duckman
Duckman
Noodle Jr.
I bought a Weltmeister kit that I am going to start on today so I will post details at a later date. It eliminates the 2 ball cups that can fail. Do a search on Weltmeister vs. RS and you can decide.
they're not THAT long
As to the original question. Do an advanced search. You'll find tons of threads about the various short-shifters. Or hopefully some of the Track/AutoX guys will weigh-in.
Guest
Posts: n/a
I Dunno; that depends on what you're used to driving. The throw lengths using the G50 in my 964 felt like a truck compared to my S2000, Miata's, or even my old (much loved) MR2 Turbo. Even my 2004 Boxster has much longer throws than I'd like. Ive been thinking about getting a GT3 shifter for the Boxster. I understand they are a direct swap.
I installed the B&M in my '95 shortly after acquiring it. I agree...the OEM shifter is "mush" and I never was quite sure just which gear I was going into...very dangerous at high rpm! The B&M is a straight-forward install and it did correct the vagueness and shortened the throw,, however, as stated above, the ball linkage is the "weak link" (pun intended).
I had the factory short shift lever in my 993, but I took it back out. It is very well made, and works well, but it increases the shifting effort too much for my taste. Also, I think that if you shift these gearboxes fast, you'd better get to know a good transmission shop--it tends to wear the internals quickly.
The factory rs lever is what I have and enjoy. It is 25% reduction I believe and was about $100 when I got it. The BM is more aggressive, 40% reduction? but I have heard mixed reviews.
As Cactus mentions the Weltmeister replaces the front portions cup joints with heim joints. I believe that has the same reduction as the rs shifter. I have been passively watching for one of these...
Pete
Pete
I've had the opportunity to drive several 911s on track and I found I liked the RS unit, but compared to the Weltmeister you really can't feel that much of a difference. Plus, it's much cheaper than the RS unit so I bought the Weltmeister kit and been happy with it the past two years.
I am interested in doing this upgrade. I went to pelican and b&m's site both and they only list a shifter kit for 996 and Boxsters. Are they discontinued? Or will these work for the 993?
I got my 993 with a B&M, feels good, but didn't have the previous to compare. I did put a WEVO in my 930 and it's a world of difference, but don't know if the make them for 993's
