Cobra Misano Install Help
I purchased these beautiful seats last week but having problem installing them. The mounting brackets fit perfectly. But the inner reclining side- **** are scraping against the center console making it difficult to slide and recline.
For those that had these installed, what was your solution? Thanks ahead.
I had a similar problem in my cab when I installed a set of Recaro Speedlines. I had to pop the plastic **** off and dremel the metal gear down so it was flush with the side of the seat. Fortunately, Recaro did supply a cover that pops over the hole when the **** is removed to tidy up the install. You may want to check with the manufacturer.
I was afraid of having to dremel off the *****. But looks like that's what it take to install these seats. BTW, Subemotorsports don't offer any covers replacing the ****.
