Got new Porsche Tools
Okay I now have one less excuse for updating my suspension.
A friend, who happens to be a jet engine mechanic, unloaded his brand new Craftsman metric tools on me as he has no use for them. I think he wanted to give them to me but I gave him $50 anyway. It includes sockets to 30mm and wrenches, open and box, to 27mm as well as 12 point and six point sockets, shallow and deep, speed wrenches, impact sockets, etc. It made my day.
ps please ignore the cheapo allen wrench sets
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
Nice! That's a lot of tools for $50...
You know though, you are going to have to turn in your man card for just now getting a good set of metric tools!!!
Just joking! Better later than never!
Cheers!
Cheers!
This makes me want to find that old thread by Jeff 993TT about putting together the perfect toolset to replace the factory one that comes with the car. Might have to put a set together as a Christmas present from me to me!
The million dollar questions is what tools am I still missing. I sure would be interested in seeing what's in the perfect toolset to cover all of the DIY jobs. Perhaps this has been posted before. I'll check it out.
link to Jeff 993TT's post
January 13, 2002
Recommended 993 toolkit
Here are the parts that I believe should be in the 993 toolkit.
I had the misfortune of my car breaking an alternator belt at the
track and finding that my toolkit was missing tools.
And of the tools that remained, they were bascially crap. For
example, the wrenches were of such inferior quality, they started
flexing after the slightest bit of pressure was applied.
During the time that I replaced my alternator belt "in the field",
I was fortuante to be with somebody with good tools. Even then, we had
to apply significant muscle to many of the bolts. There is absolutely
no possible way that I could have completed my repairs using only the 993
toolkit. Using the included 993 toolkit to service your car could be
hazardous to your personal safety.
Here are a list of things that I believe allow you to make simple roadside
repairs. This is based on my experience of replacing the alternator belt and
changing tires. I'll add to this list as my experience grows.
The items in the above picture are:
1. 8 mm combination wrench
2. 10 mm combination wrench
3. 13 mm combination wrench
4. 17 mm combination wrench
Note: All the above wrenches are commonly available as a set.
5. 24 mm combination wrench
Used to loosen the alternator nut if you are changing your alternator/fan belts.
Note: This wrench is not usually part of a set and should be bought seperately.
6. Folding Hex Key Set. This piece is not required, but there are a lot of hex bolts and this may come in handy.
7. 6 mm 3/8" drive bit socket
Used to remove the 3 intercooler bolts from the engine.
8. 5 mm 3/8" drive bit socket
Used to remove the 3 bolts from the fan belt pulley.
Note: The above two items are also available as part of a set here.
9. Oops, jumped a number in my picture above.
10. 3" 3/8 drive extension
11. 3/8" drive ratchet
12. 1/2" drive 19 MM 6 point ratchet head
Used to remove the wheel lug nuts
13. 1/2" drive 17 MM 6 point ratchet head
Note: The picture shows a 12 point socket, but purchase the 6 point socket instead. It is stronger.
14. 1/2" drive 6" extension
15. 1/2" drive flex handle
Note: The picture above is a 1/2" drive ratchet. Either the flex handle or ratchet is fine.
16. Tow hook, part of the standard 993 toolkit
17. Unknown 8 mm tool, part of the standard 993 toolkit
18. Unknown tool with 5 mm hex on one end, part of the standard 993 toolkit
19. Universal jointed spark plug tool, part of the standard 993 toolkit
20. Right angle screwdriver tool, part of the standard 993 toolkit
21. 12 point allen head, Porsche Part #999 571 052 02. [Pic]
Note: This tool is commonly missing from the 993 toolkits and is absolutely necessary to change the alternator belt.
If you want to find out Robin's order with a stripped alternator shaft, look here.
22. 4 in 1 screwdriver. Get a decent one from any hardware shop.
23. Magnetic pickup tool. This is optional, but definately comes in handy.
24. A decent pair of pliers.
In addition to those tools, I would also recommend the following:
25. DME relay update used to fix intermittent starting problems. Porsche Part # 993.615.227.00
Not all relays are defective. Here is more information here
26. Extra fuses, 30 A, 25 A, and 15 A blade type fuses.
27. Alternator belt, Porsche Part # 999 192 372 50. 9.5 mm X 757 mm
Note: This is for 993 TT with the alternator pulley update applied. Normally aspirated may be different, please check your owner's manual.
28. Fan belt, Porsche Part # 999 192 343 50. 9.5 mm X 760 mm
Note: This is for a 993 TT, normally aspirated models may be different, please check your owner's manual.
29. AC belt, Porsche Part # 999 192 363 50. 13 mm X 1085 mm
When I prepare for long drives and track days, I take all of these tools with me just in case I
cannot get help in other ways. However, in everyday driving, I take a reduced set of tools, namely my AAA card.
Jeff
Email me
Posted by Jeff 993TT at 12:07 PM
Perhaps a credit card would be lighter ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Yeah I'm set to go now. I just need a clutch slave cylinder and a set of Bilstein HD's and M030's and Chris Walrod control arm bushings and perhaps some motor mounts and...
