RS hood prop
Yes, but the struts themselves weigh almost nothing. The real reason for the prop is that the struts are too strong for a fiberglass hood (and maybe too strong for an aluminum one). The steel hood weighs a ton.
Where can I get the RS prop? I added a Das Shield (ABS hood protection liner) to my car. I have new struts, but the added weight is too much for the struts to hold up on their own.
Where and how much $ would be good to know.
Thanks!!!!!!! Geo. B.
I used the RS rod because the struts would not hold the hood up when I was using my magnetic bra, that and it looks cool.
Bill gave me a hard time about still having the struts in so I took them out, they do weigh nothing.
I got the parts from Porsche using the ROW parts catalog. For all the parts it was about $40.
Mike
Mike
Unless you are stuck on using the factory part, I like the Ultimate Hood Strut from Seine Systems. No drilling and < 4oz.
Not quite the same and a little heavier but very sturdy.
http://www.sears.com/shc/s/p_10153_12605_00947316000P
dave
dave
The rod and stowed position latch (steel) require drilling the hood (four holes for the rod, two for the latch).
I have no concerns about drilling or modifying the car however I want to.
If you really want to go low dollar use a fitted broom stick, which I did until I got around to installing the rod.
Mike
Mike
