993 Forum 1995-1998
Headlight washer delete - pros/cons??
Old Nov 19, 2008 | 01:17 AM
dcdude's Avatar
dcdude
Originally Posted by rome
Personally, I like to keep the car as close to stock as possible (suspension aside)...
+1. Same with rain gutters. These things don't offend me...I'm not feelin' it. I will remove bumperettes and other US-only B.S. But first, two dumb questions:
1) How do you make the washers work? Lights on, hit windshield washer?
2) That said, if you do take 'em out, do you have to plug and clamp the lines for fear of squirting washer fluid somewhere aft of the front bumper? I like all the loose ends tied up (whoa..apt expression!)
Old Nov 19, 2008 | 03:14 AM
Monique's Avatar
Monique
AFAIK, no one uses the headlight washers...
Off with the ugly bumper zits too....
Brazilian............ look
Old Nov 19, 2008 | 04:19 AM
Stewart's Avatar
Stewart
If you've got HIDs or intending to retrofit them, you really need the washers. The HID light pattern is dispersed and becomes ineffective significantly quicker than standard lamps with dirt on the lens.
Old Nov 19, 2008 | 08:34 AM
Akerlie's Avatar
Akerlie
EU directives require washers if you have Litronics (HID) otherwise i would have gone for a delete.
Old Nov 19, 2008 | 09:39 AM
bart1's Avatar
bart1
Pull stem for windshield washer, push for headlights. Says so in the owners manual! I understand it creates an interesting light show the first time you use it at night with the lights on.
Old Nov 19, 2008 | 10:25 AM
V's Avatar
V
+1, I knew that was coming..
So now the question is (for us ROW people):
-HIDs and f-ugly headlight washers
or
-Crappy halogens and front fenders "Brazilian Style"????
Old Nov 19, 2008 | 01:00 PM
Reuben's Avatar
Reuben
I'm with the 'Brazilian' brigade, having had the headlight washer nozzles filled (metal) and switched to a Euro Turbo bumper cover also. Smooth is good - and surely the reduced drag must improve fuel consumption considerably, too!
Old Nov 19, 2008 | 01:02 PM
NP993's Avatar
NP993
Bow down to your bureaucratic masters!
Old Nov 19, 2008 | 02:13 PM
Garth S's Avatar
Garth S
#1 - yes
#2 - pic is shot through the left headlight slot: pull the connector off the pump on the right and plug the pump discharge ( 2" cut off of the same hose with a bolt in one end) .... should do the trick.
PS - Don't let Andreas see that pic - I haven't dusted the insides of my fenders yet
Hummm - shop wants 4 hours additional to weld & fill the headlight jet holes, plus I may lose my time slot in the paint booth: snow forcast tonight, so body shops must be slapping hands in glee for the onslaught of fender dingers ..... for they do better $$$$ on insurance claims than on me
We'll see - at least, the 'zits' are only slightly visible against very dark blue - which is the rational to keep the bumperettes
File Type: jpg
Old Nov 19, 2008 | 02:33 PM
J.A.W.S.'s Avatar
J.A.W.S.
or
same here. vote for the brazilian style way.....
Old Nov 19, 2008 | 03:25 PM
cmoss
Guest
Posts: n/a
Thanks for looking that up for us. Honestly, I've had the car for the last seven years and never once used the headlight washers--never even bothered to learn how to turn 'em on. Stll and all, I might give them a try--just to see if they work.
Old Nov 19, 2008 | 03:32 PM
bart1's Avatar
bart1
I haven't used the washer either, just know it's there.
Old Nov 19, 2008 | 06:29 PM
Mark Harris's Avatar
Mark Harris
I had never used them either and one day I decided to make them squirk just for fun.....pushed and pushed...no squirt.
If I remember correctly, the headlights have to be turned on before they squirt
Duh.....
Old Nov 19, 2008 | 07:09 PM
sdcabrio's Avatar
sdcabrio
The jets don't bother me nearly as much as the bumperettes. I would lose the bumperettes and leave the headlight squirters. As someone earlier said, I'm for making my 993 as close as possible to it's cousins in the motherland by losing the U.S. only crap.
Old Nov 19, 2008 | 09:52 PM
Chuck W.'s Avatar
Chuck W.
Not only did I remove the headlight nozzles I also removed the tank from under the front left fender. I never use the washers on the windshield.
