993 Forum 1995-1998
Secondary Air Injection pump noise?
Old Nov 17, 2008 | 12:42 PM
BobbyT's Avatar
BobbyT
Default Secondary Air Injection pump noise?
What I earlier described as a "squeal" is more like a "bzzzzt" noise, when the engine is started cold, just for a second or so, and just as the engine fires up. Is this a normal SAI pump noise? Is the pump electrical? My car is a 95, so no evil SAI fault codes...
I just replaced the alternator, so I'm overly sensitive to engine noises.
Old Nov 17, 2008 | 01:01 PM
Allen's Avatar
Allen
Since you just replaced the alternator...it's not belt slippage squeal is it?
Old Nov 17, 2008 | 01:50 PM
brucec59's Avatar
brucec59
The air pump comes on several seconds after starting and stays on for a minute or so. At least that's what I've leared from other threads here:
https://rennlist.com/forums/993-forum/445702-air-pump-noise.html
https://rennlist.com/forums/993-forum/235426-whistle-sound-from-engine-on-cold-start.html
