Multivex mirrors
I just noticed the boxes in Paul's pics show an address in Paulding OH, while David's link is to a company in Romulus, MI. I also have seen what looks like the same thing at www.safetymirrorsonline.com, which is in Detroit.
Where did you guys order yours?
Thanks for that David, the last point you mention is the reason I didn't go for the Porsche ones either. I have to reverse my car into my garage and at present I can do it cm perfect. Not so sure with mirrors that distort the distances you have to play with. I recently had to park a Vauxhall (GM to you guys) in a tight spot and when I got out of the car I couldn't get a finger between the side of the car and a pillar it was parked next to. The thought of doing that with my 911 brings me out in a cold sweat.
David,
Thanks for the great write-up! The photos really help. I appreciate your time and will definitely consider these. I currently use a small, round convex mirror for the driver's side mirror and a larger convex mirror for the passenger's side. The driver's side mirror is helpful but less than ideal because it's too small. However, if I use a larger convex mirror, I lose the "flatter", non-convex view.
David,
I did get them for the drivers side...just don't have pics yet. May try to get some tomorrow but I'm trying to finish up my V1 mount project. I'll also take some pics of my black silicone sealing I did to seal up the gap on the tops and sides.
I just came across this link for aspheric mirrors for a Boxster with pics that compare the view with the factory mirrors. Also a fairly good summary of the pros and cons.
aspheric mirrors for Boxsters
The Boxster Aspheric Mirror Page
This page describes the aspheric (wide angle) mirrors for the Porsche Boxster. They are an easy plug-in replacement (directions below) for the standard U.S. mirrors.
Why would I want them?
Because they cover a wider angle than the standard U.S. mirrors. Here are some photos showing the angles covered. (See below for details of how they were taken.)
Standard U.S. Mirrors:
The driver's side mirror covers an angle of about 18º, with a normal perspective allowing accurate judging of distance. The passenger's side mirror covers about 25º, and objects in mirror are, to coin a phrase, closer than they appear.
Aspheric Mirrors:
The mirrors are identical in coverage, but because the driver is closer to the driver's mirror, it covers an angle of about 42º while the passenger mirror covers about 38º. Distance is difficult to judge; objects seem even further away in the driver's side aspheric mirror than they do in the standard passenger side mirror.
How do they do that?
By using different degrees of convexity. 80% of the aspheric mirror is a convex wide-angle surface similar to the U.S. passenger side mirror. The outside 20% of the mirror is super wide-angle, getting progressively more convex toward the outside edge. You can see objects in this part of the mirror, but they are scrunched horizontally, so much so that at the edge of the mirror they are hard to identify. But you can see whether something is there or not.
Why would I not want them?
Because it is even harder to gauge distance in these mirrors than in the standard wide-angle U.S. passenger-side mirror. This is mostly of concern with the driver's side mirror. Some people have gotten used to them. Some people have reported near-accidents with them.
How can I get them?
The Porsche part numbers are 996 731 035 02 for the driver's mirror, and 996 731 036 02 for the passenger side mirror. As far as I know they are not sold in the U.S. They can be ordered from Chris Kramer in Germany.
How can I find out more about them?
Don't ask me - everything I know is on this page. You can email Chris, or post your questions on Porsche Pete's Boxster Board.
How do these mirrors install?
Here's the step by step demonstration given at BoxsterFest II by Randy Russell. Randy organizes the 'Fests, and also has placed some pool orders for items from Chris Kramer in order to share the shipping charges from Germany. Randy insisted that we find a better looking pair of hands than his, so Boxsterwaiter Leslie Wallace volunteered.
1. Using the electric mirror control, tilt the mirror as far down and toward the vehicle as it will go.
2. Work a finger or two behind the upper outside corner of the mirror and start to pry it out. As you can see from the next two pictures below, there's a large mounting ring in the center, so try to work your fingers behind the mirror and closer to the ring as you pull out. It takes a fair amount of force but the mirror is sturdier than it looks.
3. As you work your fingers behind the mirror and continue to apply force, the mirror will suddenly snap out with a terrifying pop. Catch it and calm yourself. The mirror is still attached by two brown wires for the heating element. If you're nervous about polarity, now's the time to make note of which wire goes where - though they're not color coded and with a heating element it shouldn't matter. Grasp one connector - not the wire - and wiggle it back and forth until the connector comes loose. Then remove the other one. Be sure to wiggle in the direction of the prong attached to the mirror - don't bend the prong. These connectors can be pretty tight so this may take some time and tugging.
4. Here's a better look at the back of the mirror. Note the big mounting ring in the center, the lugs for the heater at the lower right, and the locator finger directly above the lugs.
5. Plug the brown wires onto the heater lugs on the mirror.
6. Look at the photo above, and note the bronze-colored locator strips just above the brown wires. Guide the locator finger on the back of the mirror between the locator strips. Then press the mirror into place, pushing on the face of the mirror in the middle, where the mounting ring is. Push until you hear the mirror snap into place. Press firmly to make sure it is seated. Hey, isn't that Randy's hand in the photo?
So how did you take those neat pictures of the mirrors?
I'm glad you asked. A set of targets (left) were printed on different colored sheets of paper, to allow them to be distinguished even in the squeezed portions of the aspheric mirrors. A base for the mirrors was constructed out of common household objects (right). A Meguiar's Unigrit Sanding Block (hidden under the towel) was the perfect size for propping up the narrow side of the mirror to get it more or less level.
The camera was placed to give a lens to mirror distance about equal to that measured in the Boxster: 24" for the driver's side mirrors and 44" for the passenger side. Because the wall was flat, the distance to the angle marker targets varied from 8 to 10 feet, which is why the targets are different distances apart.
The aspheric mirror does not focus uniformly across its width. The eye copes pretty well with this; on the car you pretty much have to look for the effect to see it. But it sure shows up when taking photos! The effect was minimized in the above photos by using a tiny aperture setting on the camera.
Aspheric Mirrors:
How can I get them?
note: edited to correct for sizes
Mirror
David: Is this the same mirror you have. Note, the second link has multiple sizes and types.
http://www.optionstage.com/rear-mirror-bw-707.html
http://www.optionstage.com/rear-view-mirror.html
All the taxi drivers here in Hong Kong use these, as well as the majority of regular cars. If you've ever driven in HK then you know these are pretty useful and for HK$120 (about US$15) it's an inexpensive mod.
PS - Father of 3: the first link above has a diagram that shows how these are affixed to the stock mirror.
David,
To be frank, I think if you are really concerned with how much of the silicone shows and having the mirrors protruding, you could probably affix the rear brackets from the factory mirrors onto the back of the Multivexes and have a cleaner look.
My wife has these on her Elise, and they're really useful there. I won't bother on my 993 because IMHO the stock are fine. I find the view a bit annoying; because your left and right eyes see very different images due to the curvature, I find it a bit visually confusing.
If you use them, don't rely on the foam tape; one of hers came loose after a while. Use some silicone either under or around to affice the mirror.
On the use of silicone, it's recommended that you use it on top and also in spots underneath...you need to leave openings for water to exit.
