993 Forum 1995-1998
Crossover install - need wiring help
Old Oct 21, 2008 | 02:29 AM
Robert-VanBC's Avatar
Robert-VanBC
Default Crossover install - need wiring help
I just removed my old tweeter and woofer speakers on my '95 C2 which were just thrashed. Over the weekend I purchased a set of component Boston Acoustics Pro 5 series which come with a crossover for each door. I rewired the new tweeter and woofer to the crossover, that I mounted in the door pocket, without any problems. There are two wires coming from the head unit, one white and the other white/brown. I have to connect these to the signal in/out of the crossover. Does anyone know which wire is +(pos) and which wire is -(neg) ? Or does it matter?
Thanks in advance
Robert
Old Oct 21, 2008 | 03:06 AM
Full Boost's Avatar
Full Boost
Why do I feel so left out!
Robert,
In short it does matter - but wont hurt anything - but it will cause the speakers to run "out of phase"
Test connect and see if you get sound then try and get them into correct phase.
Try connecting both the same and then see if the sound imporves if you "swap" one set over... Bass will be the way you will find out...
Hope this helps,
SImon.
Old Oct 21, 2008 | 09:36 AM
bart1's Avatar
bart1
You can also check polarity with a battery - I'll let you google for some good instructions.
Old Oct 21, 2008 | 11:48 AM
bart1's Avatar
bart1
Here ya go: http://www.carstereo.com/help/Articles.cfm?id=67
