Big Reds Overkill?
#32
That's what I was always told, too. I bring my VWs to a well-respected shop that has been around since the 70s, and they race VWs, and therefore have a racing perspective on much of what they do. A while back, they put pads on my Jetta that had more of a racing compound, and they REALLY sucked in the winter because they never got hot enough to work well in every day traffic. After several stops, they would work better. I had them changed out for a more street-style compound, and they worked so well, I had the Beetle switched to the same type. I run OEM 993 Turbo Big Reds and OEM Turbo discs with Hawk street pads, whereas before I was using Porterfields on both VWs. I definitely like the Hawks for daily use. I don't know what's on the 993 as I just bought the car and the pads were still good.
#33
Although I am not necessarily convinced that Boston911fan's incident could not have had the same results with small black brakes, I, too, agree that, depending on the previous temperatures of the brake pads, hotter pads might have offered better stopping power than coler pads, no matter the size of the caliper and rotor.
#34
#35
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
There is an optimum temperature range for all friction materials like used in brake pads, clutch discs etc.
This is something I have learned a great deal about in racing. Too cold leads to no grip, too hot, grip or mu degrades. Carbon-carbon materials literally have no friction when cold.
We play around with different compounds all of the time. Some have better initial bite, some better deeper in braking zones even some with higher compressibility factor for bumpy street circuits.
In the end, there is a sweet spot in which friction materials like to live. Street or OEM products are engineered to work well cold or near cold and are quiet.
This is hot!
http://www.youtube.com/watch?v=66rhipiuR00
This is hot!
#37
Big Reds are Sweeeeeeeeeeeet! :D
FWIW, the PO had upgraded my 993 with them after supercharging the engine (Rocket C2 Cab.)! I don't track my car, but do drive the heck out of it, I haven't had to change the brake pads nor rotors yet (bought it in Summer of 2001) !
