Sway bar drop links
Sway bar drop links
We recently acquired a 993 as a track car and it came with bigger sway bars and HD shocks. Upon teching the car it appears that the drop links (front) are too long and put the sway bar in contact with the edge of the lower control arm.
Are the drop links the wrong ones or is there something else the matter?
Assuming it's the drop links, which ones should we be using?
Factory drop links should work too.
Oh wait a minute... are you SURE you mean the front? This is typically a problem with the rear, not the front.
