View Poll Results: Do you "pre-lube" the engine before firing up?
Yes, I disable the engine and turn it over a bit.
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
18
24.32%
No, I just fire it right up.
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
56
75.68%
Voters: 74. You may not vote on this poll
After changing oil, do you crank the engine before firing up?
RL Technical Advisor
The only time I crank an engine to build oil pressure before starting is with the initial start-up of a brand new engine on the dyno.
After an oil change on a 911, I simply start it right up,.......
If a person were really O/C, one could pre-fill a vertically mounted oil filter, but its not critical at all.
