Rear Alignment Question
Hey Everyone,
Two questions regarding rear wheel alignment. My car runs PSS9's and runs slightly lower than RS specs height.
1: Can I adjust the rear camber without adversly affecting the rest of the alignment?
2: What is the maximun amount or rear camber available with stock rear suspension?
Your responses are greatly appreciated....
Regards
Regards
2. You should be able to get -1.8 to -2.0 camber on the rear without monoballs.
I do remember the thing steered like a pig and ate tires for breakfast...
Dave
Eric has much more experience with this than I, but you might be able to get a little more without. When I bought my car it was between ROW and RS ride height and was running about -2.3 degrees camber in back (don't recall if there was any more to be had).
Dave
Dave
1. yes
2. I think you can get more in the rear, but the fronts limit out at around -1.8(depending on ride height), so going beyond -2.2 or -2.3 in the rear may lead to some handling issues.
