Failed Smog...Italian Tune up!!???
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
That said, it won't hurt to put a big bottle in with a full tank in a 993 when you are trying to solve a problem.
I can't recall what emissions issue you have... but good luck! Hope it works for you.
Pour it in.
Fill your tank.
Drive... like it was meant to be driven. Wind it up
After my car sat in the shop for several months, I failed my smog test the first time too. I tried a product by CRC called "Gauranteed to Pass". All I did was add it to a fresh tank of gas, then take my car out for a spirited drive and burned about 1/4 tank, then took it back while it was all warmed up, and it passed. I don't know if it was the fresh gas, the italian tune up or the G2P, but it only cost about $6-7.
Some here time their use of Techron just prior to oil change. I'm not sure it matters on a well maintained, driven right (to redline on most drives), non-stop/go driven motors.
If the car idles for long periods in traffic or is driven lightly then this is probably a good idea as there would be more schmeg to clear out.
Techron itself burns with the fuel. I really doubt there is much residiual from the product ending up in the oil.
All my opinion, of course.
oh and yes, run through the entire tank of fuel with the additive.
I go to the same emissions and safety shop (4x a year) and the guy who owns the place said that he has heard about every trick in the book. A majority of them do not work.
His suggestion to people is a fresh oil change, high octane gas, and blow out a little steam with the car before you come in for testing. Maybe try a can of BG-44k. I put a can in every 3 or 4 months anyway. When you go again for emissions, ask them to stop the test if its going to fail. The right shop can do that.
For carb based vehicles, its turning the carb down so it runs like crap and that seems to make them pass. That is the ONLY thing that worked for my Bronco. I did the fresh oil change (even though it was only changed 700 miles prior), paid like $65 to have one of those kits hooked up and clean things out, and then my time. So I spent about $125 and a few hours of my time trying the tricks and the end result was nothing. Turned down my carb so it wouldnt run "rich" and passed with flying colors.
