Changed my brake master cylinder, now have a soft pedal. What'd I do wrong?
So I replaced my brake master cylinder and bled all 4 corners, but my brake pedal is complete mush. However, I did NOT operate the brake pedal while bleeding (just used a power bleeder). Will re-bleeding solve it, or do I need to have the ABS bled with a Hammer / Durametric?
Changing the m/c was actually pretty easy... too bad I screwed it up!
Go out for a drive and find a dirt road where it is safe and get the ABS to fire up and then bleed the brakes again. Sounds like you might have air bubble straped in your ABS system.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Or air still in the M/C. Its usually best to bench bleed the m/c before installing. Keep bleeding. Also, you can cycle your ignition switch in between bleeds.
+1. You also may want to do the rubber mallet tap on the calipers during bleeding, I am always suprised at how much air comes out doing that.
I can't do that because the pedal is complete mush, i.e. no brakes at all. Perhaps that supports Chris' comment that air is trapped in the m/c.
If you didn't bench bleed the MC, that's probably the culprit. Way back when I changed the MC on my old 911 without knowing about bench bleeding...and bleeding the damned thing took forever, and I could never get a hard pedal. I finally just pulled it out and bench bled it, and all was good after that.
Thanks for the advice.
