Need a seat motor fix or part - Help!! have part #
1995 993 Cabriolet
Part # 928 624 136 00
Bosch # 390 206 675
My seat will not move forwards or backwards. The switch is fine as well as the flexible cables. When I hit the switch on the seat the motor engages, but does not move forward or backward. I have not interchanged the one from the drivers side yet. I also tried to move the seat manually by inserting a hex key in the opening next to the motor. This would not even budge the seat in any direction. I tried the hex key on the drivers side and it moved manually with ease. I pulled the motor out of the seat and it is very hard to move manually and it sticks from time to time. So I have come to the conclusion that the seat motor is bad. Does anyone have a fix or a extra motor they would want to sell? Stealer wants $355.00 for this part. TIA
Mike
Bosch # 390 206 675
Mike
fix
Mike,
Your seat symptoms sound similar to the issues I had. I followed a great DIY from Garrett and saved some bucks. Check it out.
https://rennlist.com/forums/964-forum/269624-reworking-the-seat-adjustment-switches-no-need-to-replace-them.html
-nelson
-nelson
Mike,
https://rennlist.com/forums/showthread.php?t=269624
-nelson
-nelson
Thanks for the link, but the switches are not the problem. They work fine and power is getting to the motor via the switch. When I depress the switch the motor acts like it wants to move but is frozen. I also know the way to move the seat manually via the hex key and this does not work either due to the motor being frozen. Thanks again. Anyone else?
Mike
I got the seat out. I am not looking to remove the seat just fix the motor that makes it move front to back. To answer your question the seat is in the rearward most position. I can get it to move with the motor removed by turning the flexible shafts. I hope this helps.
Mike
Mike
The reason i ask, is that for some reason with the 993's, if you put the seat all the way back with the motor, it will get stuck. You can hear the motor engage when you use the switch, but it won't move. I have always been able to sit there and tap the switch over and over again, and eventually it will release and move forward. Sometimes you get it in 30 seconds, sometimes it takes 10 minutes. We see this a lot in the shop when guys put the seats back all the way. For some reason it is only in the 993's that I have noticed it happen.
Mike
stuck seat
...you sit there and tap the switch over and over..PorscheDoc
I'm thinking of taking it to the Beartooth in a week or two, and it would be helpful if my wife could drive some legs.
Thanks for the tip. Is converting to a mechanical seat a big deal, assuming I can find a seat in Cashmere?
Rinty
So I take it that it probably won't damage anything further by repeatedly applying the switch? The seat in my '96 993 is stuck and I haven't been able to skootch it forward.
Rinty
Rinty
