993 Forum 1995-1998
What weight floor jack?
Old Aug 24, 2008 | 09:20 PM
ste993's Avatar
ste993
Default What weight floor jack?
I'm looking to purchase a floor jack for my car and was wondering what weight rated jack I need for my 993. I will use it to jack the car up and then put it on axel stands (2) before I work on it. Any advise?
Old Aug 24, 2008 | 09:43 PM
gr1275's Avatar
gr1275
I use a 1.5 ton I picked up from Sears. Seems to have both the capacity needed as well as the lift height.
Old Aug 24, 2008 | 09:46 PM
Smiles's Avatar
Smiles
I'm going to reply to Steve's post because I want something similar. I'd like a low saddle height jack that's lightweight (perhaps aluminum) that's also smaller so that it's easy to haul around to DE days. (I usually don't like Harbor Freight, if that matters.)
Thanks in advance!
Old Aug 24, 2008 | 10:17 PM
ste993's Avatar
ste993
Thanks in advance!
A good friend of mine who races semi-pro uses recommends this lightweight jack from Harbor Freight:
http://www.harborfreight.com/cpi/cta...emnumber=91039
However, being a contractor, I have never been keen on Harbor Freight tools simply because they don't seem to handle the abuse of daily hard use. But I'm thinking that perhaps this would do for the light use I will give it and, as I said before, my friend has used and abused this jack most weekends for more than 18 months and still recommends it. I'm considering buying one but want to find out what others recommend here too.
Old Aug 24, 2008 | 11:49 PM
mcpiaseczny's Avatar
mcpiaseczny
I used to use the Sears jack but they seem to deteriorate with age (I went through two of them, and I don't abuse them in any way). So I picked up a 3 ton low profile aluminum jack from Costco a year ago and I love it. I can get all the way under the crank case on my lowered car without problem and it jacks quickly. The only downside is that it's big and heavy.
Old Aug 25, 2008 | 10:55 AM
TAI2's Avatar
TAI2
I don't have a particular brand to reccomend and I do not know what kind of suspension you have, but I would measure the amount of clearance you have under your car and get one that will fit without having to drive your car onto wooden ramps (ask me why I knw this is improtant).
Old Aug 25, 2008 | 12:00 PM
ppressle's Avatar
ppressle
I have a Lincoln 2T steel floor jack. It is bullet proof. I would highly recommend one of these. Downside is that it is big and heavy. I also have the Costco aluminum. Of the two the Lincoln is MUCH more robust. The Costco is ok if you need to transport it though. The Costco also has a slightly lower saddle height, but not enough that it is an issue.
Update. Can't find the Lincoln for sale, but it looks something like this one: http://www.tooltopia.com/index.asp?P...D&ProdID=31010
Old Aug 25, 2008 | 12:12 PM
Sooner's Avatar
Sooner
I have the harbor freight, been using it for 3 years with no issues. I use it about once a month or so.
Old Aug 25, 2008 | 12:55 PM
Edward's Avatar
Edward
Addicted Specialist
Been using the Sears Craftsman Alum "race" jack now for years, at home and taken to track, still works as good as new.
Edward
Old Aug 25, 2008 | 02:55 PM
993Maineiac's Avatar
993Maineiac
+1 5 years old and use it with 3 cars-no problems so far.
Old Aug 25, 2008 | 10:11 PM
AX993's Avatar
AX993
I've had the Harbor Freight 3000 lb lightweight jack, but it went bad after about a dozen uses. HF took it back under warranty and I placed the cost of that one towards their 4000 lb lightweight aluminum jack (It was a floor display model). I'd rate it (the 4000lb one) as just OK. It is difficult to pump up and one of the first times I used it, it twisted sideways on me, because I didn't know I would have to re-torque all the frame nuts and bolts, as it was already "assembled".
My wife, bless her heart, bought me one of those really nice AC-Hydraulic jacks. I only use the HF one as a back-up and hold my breath when I do use it.
of course, as always, YMMV
Old Aug 25, 2008 | 10:22 PM
Smiles's Avatar
Smiles
I think that this post reveals some problems with Harbor Freight stuff: its quality is very inconsistent, and it often needs to be fixed so that, although brand new, it will work properly.
I have a HF knock-off of a sheetmetal Beverley shear, which I think works great; others hate it because the cutting blades chip. Mine have been fine, but I also had to spend some time adjusting them.
The drill press I bought from them was terrible. The cast pot metal pieces kept cracking.
It's really hit or miss with them. But their prices are so cheap, I keep going back!
Old Aug 25, 2008 | 10:37 PM
avidtest's Avatar
avidtest
I had a Sears Craftsman aluminum jack. It worked great!..........for about 5 months. I then read some threads that I should have read before I bought it. The hydraulics go out on them very regularly. And Sears does not warranty them beyond 90-days. Craftsman is not what it used to be.
Anyway, I know own one of the Costco aluminum jacks (Arcan brand) and have been using it regularly over a year. I'm very happy with it. Also, my car is very low and this jack gets under the car everywhere I need it to.
If you'd like to see what others think of the Craftsman jacks, just look what they have to say about them on Sear's own site: http://www.sears.com/shc/s/p_10153_1...Lift+Equipment
And here are some reviews of the low-profile one: http://www.sears.com/shc/s/p_10153_1...Lift+Equipment
