Just installed an oil cooler fan bypass....circuit question
and I used this little radio shack toggle (Pt#275-0010). The body fits snugly inside of the console blank. Works beautifully and I sort of like it's funky look better than the 944 hazard switch I was going to use.
Question for all you electronics guys:
Is it possible to build a little battery powered circuit so the LED will light up in the open circuit position? It obviously doesn't light up now in either position because theres no voltage at either position. So I'd like to build a little powered circuit as long as it's safe and doesn't feed back into the CCU.
thanks
thanks
