HID Xenon headlight died, then the other...
I've got an aftermarket HID Xenon headlight system (VTX Performance ballast, quite possibly sourced from Vertex by the PO). This is the first time I've had to trouble shoot one of these, so bear with me...
Do the ballasts die when the bulbs go out???
So my right low beam went out (still had left side working...for a bit...) I pulled it out and found that the bulb was cracked at the base...no biggie, off I go looking for a replacement....not just a standard bub from Kragen....dang. I was double checking to see if the ballast had died as well and put the bulb back in, headlight back in, and then found out that the left low beam now doesn't work now either,
where it had been before.
Plugging the 12V connector into the ballast, I can get the right (cracked bulb) to flash like it wants to start, then nothing... This means I'm getting power to the ballast and it seems like it wants to work... I don't get that same flash on the left (2nd to die) side.
I was thinking blown fuse, but the right side still can flash like it wants to start, so there's power applied....
Did I just have 2 bulbs die nearly at the same time? Since the left doesn't do the flash when I plug the cable into the ballast, is that ballast now dead?
i was going to buy 2 new bubs, but I want to be sure that will fix the issue. The 2nd bulb dying right after the first is a little suspicious to me...
Thanks in advance for your shared wisdom...
Keith
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Keith
here is how I would diagnose, do you get 12V to the input of to the ballast? you can test this most easily with a voltmeter, or plug in an H1 bulb. if you get 12+ Volts at the ballast, then swap the bulbs to see if one of them lights, it is unlikely (although possible) that both bulbs went bad at the same time. if one of the bulbs lights, then the other is bad, if neither lights, swap the ballasts and see if the other ballast will light one (or both bulbs) most likely ONE component has gone bad, by mixing and matching you should be able to determine which component is bad.
you can get replacement ballasts and bulbs on line. If you don't even get 12v to the input, it is either wiring or fuse.
Although OTOH, HID kits have gotten so cheap, (I got a kit for $50 a few months ago) you can just replace the whole kit) as suggested by pjconner.
Had the same thing happen- or at least one bulb/ballast die (VTX from Vertex).
I mounted the ballast inside the headlight assembly but will move it outboard- I think its overheating.
I've had no problem with my other cars when using similar kits (even cheaper fleaBay versions) as long as the ballast was trunk mounted so I will go back to this method of mounting.
![](https://rennlist.com/forums/images/ranks/veteran_army.png)
Unfortunately I don't have a multimeter that goes above 5kV, so I couldn't really trouble shoot the HV stuff. (yea, yea, I know...not a good place to be messing around. Definitely not recommended for anyone, but I'm a "trained professional" here....)
So, are all these kits basically standardized? Same connectors, similar ballasts and swappable parts?
As always, RL is very helpful! Thanks guys!
Keith
I wouldn't assume that since the High Beams work, that the low beams are getting 12V also, they are on separate wires, and switched differently, I don't quite understand how your ballast is tapped off the High beam line, as that would mean you have to have the high beams on for your HIDs to be on, doesn't make sense to me. Unless you are using the 12v (from the High Beam) and a relay switched from the low beam? in which case, the relay might be bad, or it is not getting switched by the low beam.
I got both my HID kits (H1 for 993 at $120 or so, last year, and 9006 kit for our Sienna a month of so ago from EBay) Yes, all the kits use standard connectors, make sure you get the right bulb.
You sound like your are technically far superior to me in testing output, etc.. My advice is just search ebay for a set in the color you want (K scale) with the SLIM ballasts. I (knock on wood) have had mine for quite awhile with no issues. Slim ballast, simple plug-n-play, stuffed everything into the headlight bucket. I think I paid $98 shipped. Good luck.
![](http://forums.rennlist.com/upload/pilothidjpg_copy2.jpg)
Note the "cooling fins". I did a trunk mount. H1 $189.99
over on the FOR SALE forum: https://rennlist.com/forums/for-sale-ads-member-to-member-fs-wtb-free/447112-fs-hid-lighting-kit.html
no association, just posting FYI
Thanks guys! As always, RL provides the answers to my questions!
I ordered a set Friday and its sitting here in my office already, off of FleaBay. LA to SD isn't far, so it was really quick....about $150 shipped. Bummer I didn't see Kika's message in time, since it is the same kit. I might buy that one anyways just to have a spare setup.
Thanks again!
Keith
Thanks again!
Keith
Update for future searchers since I had a unique ending to my non-functioning HID headlight issue...
The original headlight that went out was only a HID/Xenon bulb replacement (i'd ordered a new full kit, so now I've got spares...).
Right side - check.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Left side (the 2nd to go out)...
replace bulb, re-mount headlight, no light
change to new ballast, re-mount headlight, no light
replace 12V wiring from light power back to ballast, re-mount headlight, no light
(sensing a pattern?)
Ohm out all connections....all OK.
Check various voltages with light mounted and lights on/off....all OK.
Check voltages at headlight assembly connector inside fender...all OK.
Remount headlight assembly....no light
Out of frustration (and a little bit of experience with electronics, but more frustration by this point) I performed "percussive maintenance" on the light. For those of you not in the electronics or computer industry (where this is a standard troubleshooting method...seriously) this is much like a Fonzie move from "Happy Days". Basically I hit the installed headlight face with my palm releasing a few frustrations.....let there be light. WTF?
Basically, the connector from the removable headlight assembly to the car was not getting fully contacted, so while everything appeared to have correct voltages, they were just not getting fully connected. All it took was properly "seating" the connector....with a fist...
Now of course I'm curious and have new HID parts in this one side and none in the other....
Replace all original parts...no light.
Repeat Fonzy treatment....light.
Left side - check!![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Hope this helps someone in the future!
Right side - check.
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Left side - check!
