Tarett Droplinks
Yes I have my TRG bar under the toe arm but I don´t think that I will need the curved RS droplinks but it would be nice with longer droplinks than the standard droplinks that I use now
If you don't care about using the 2 stiffest settings then I suppose you can get away w/ a straight one. I wouldn't though.
From your pic it appears that you currently have the stock n/a straight drop link.
here's mine, TRG w/ RS drops
![](http://forums.pelicanparts.com/uploads11/10_24_07_+0071193257140.jpg)
I've since changed to the 993RS rear bar but the rest of the setup is the same
![](http://forums.pelicanparts.com/uploads13/3_17_07_+0051212407937.jpg)
