Retro fit LSD?
Thinking about fitting an LSD to my C2 and have some questions?
1 Has anyone here done it?
2 How difficult/easy is it?
3 How much is it likely to cost?
4 What are the benefits?
Cheers guys
GG
Cheers guys
GG
It's not real bad but not for an amateur, A good lsd will run $1500 to $3000 for the parts
for street use not real benefical and can in fact be dangerous, it can double the off axis forces that can cause a spin in certain conditions, on track they are very beneficial
The benefits are more power to the ground in tighter corners, enhanced braking stability assuming you're using a clutch-type LSD and not a Torsen and more understeer, which can help if you are trail-braking.
Lots of threads in the archives.
