993 Forum 1995-1998
Rocker help
Old Jul 16, 2008 | 12:07 AM
Raptor's Avatar
Raptor
Default Rocker help
I drove an '83 cab for 20 years and impulsively bought a 993 five years ago. I had no idea of the extent of possible options/mods. The '83 had a full leather option and not a lot more. Then a friend(?) pointed me to Rennlist and I started the slide. Finally getting close to the bottom of the hill. The Gemballa aero kit was on the car when I bought it. Anyway, I am finally getting around to changing to stock. Hence this post.
What is the best process for reversing this - tig weld new rockers or fill the hole? The pisser is that I need the lower rocker covers, too.
Any help/thoughts would be appreciated (sans "SoCal Ford Probe" comments). Thanks.
BEFORE: http://i175.photobucket.com/albums/w...sj/CARRERA.jpg
AFTER: http://i175.photobucket.com/albums/w...j/DSC00552.jpg
Old Jul 16, 2008 | 02:09 PM
TomF's Avatar
TomF
Ouch. Ususally the rockers are just glued on and the brake duct is cosmetic, not functional. That part of the rocker is attached to the rear quarter panel. I would talk to a competent bodyshop and see if they can weld in a patch. Fortunately, it is covered with textured paint so it covers well...unfortunately, it will be visible from inside the wheel well on close scrutiny.
Old Jul 16, 2008 | 02:17 PM
AOW162435's Avatar
AOW162435
Seared
I agree with Tom. As long as the lower rocker metal is not damaged in other ways, have the opening closed and protected properly. Then purchase the black plastic rocker covers and hardware for the bottom - they are roughly $80 each from Sunset Porsche.
Andreas
Old Jul 16, 2008 | 02:45 PM
Raptor's Avatar
Raptor
Tom/Andrea: Thanks for the help from "pros." I was ambivalent about filling the hole. The Gemballas actually do route air to the brakes - just sorta overkill for a non-track Tip. Appreciate your responses.
Old Jul 16, 2008 | 03:23 PM
David in LA's Avatar
David in LA
You could replace with the techart side skirts which are a lot more subtle
Old Jul 16, 2008 | 07:34 PM
Arena993's Avatar
Arena993
Aerokit 1b side sirts will cover that as well Look at my rockers on my old car.
mike
